Framerate change on locked cut?
Hi all, I produced a feature that is now being picked up by a distributor, somewhere along the line our editor accidentally changed the frame rate from 24p to 30 and now the resulting exported file shows as 30 frames. The distributor requested that we re-edit or change the frame rate back to 24p, but the editors I’ve shown have said that the conversion can’t be done and we have to re-edit. My thought, to save 2 weeks of work (and money our modest indie film doesn’t have), is to export an xml of the 30 frames per second cut and reimport that xml into a 24p timeline… would this work? This way we can easily bring back in our davinci color xml and have everything line up perfectly… really REALLY don’t want to have to go back into davinci 😛
thank you for your help!
