Activity Forums Blackmagic Design Framelink – how’s it done?
  • Framelink – how’s it done?
    Posted by Rupert Watson on August 2, 2005 at 10:57 pm
    Can soneone point me in the direction of the doc I need to read to understand all I can do, and how I can do it, with Framelink? I like to think I am not totally dim, but I haven’t figured it out by just fiddling yet. I know what it does in principal. I am after instructions for how to make a QT look like DPX files in practice. Is there a KB entry or a pdf that spells it out on BlackMagic’s very pretty web site?
    Rupert Watson replied 21 years, 1 month ago 3 Members · 6 Replies
  • Rupert Watson
    August 7, 2005 at 9:59 pm
    Nobody using the Framelink function, then? Ah well.
  • Kristian Lam
    August 7, 2005 at 11:49 pm
    Hi Rupert,
    Simply drag your QT movie file onto the FrameLink application icon. This will mount a disk image on your desktop that has the DPX files.
    To create a QT movie from a series of DPXs, double-click on the FrameLink application and fill in the preferences about the type of movie you’re creating and an empty disk image will show up on the desktop with a QT movie of the same filename. Just copy the DPX files into the disk image and the QT movie will update itself.
    Kristian Lam
    Blackmagic Design
  • Rupert Watson
    August 8, 2005 at 8:14 am
    Kristian
    Thanks for taking the time to post.
    Is this on the web site? I looked through the manual and the read me and you explanation was the shortest and the clearest 😉
  • Luca De luca
    August 8, 2005 at 9:27 am
    hi all
    I’ m very interested on 2k workflow. The results in final cut are very amazing … but there is still a trouble … do someone knows if will be supported the embedded timecode
    in dpx files … It will be great for 2k conforming in fcp …
  • Rupert Watson
    August 8, 2005 at 5:33 pm
    OK that works great.
    Is there any way to determine where it pops the disk image with the DPX files in?
    On the Mac I downloaded Sharepoints 3.5.3 and can use that to make the Framelink disk image an SMB and AFP share even on an OS X client. It is very clever.
    Any plans to support timecode?
  • Rupert Watson
    August 9, 2005 at 1:10 pm
    Right – next question.
    Can you put an audio file somewhere to make the QT from the dpx files have audio?? 🙂
    If not, consider that a feature request!
