Activity Forums Blackmagic Design Framelink Crash
  • Framelink Crash
    Posted by Adrian Tecson on November 11, 2006 at 8:32 am
    Recently, I’ve had the need to create a a single file from a DPX sequence. I started fiddling with framelink but then in the 5.4 drivers, Framelink would reboot the workstation without warning upon choosing thw desired frame size from the drop down menu. Anyone have a similar experience?
    Workstation Specs:
    Dual Xeon
    SuperMicro X6DA8-G2
    2GB RAM
    Decklink Extreme
    5.6 drivers
    Adrian Tecson replied 19 years, 5 months ago 2 Members · 2 Replies
  • Kristian Lam
    November 15, 2006 at 11:46 pm
    Hi Adrian,
    Have you tried the latest driver to see if this is still happening? The latest driver can be found here:
    https://blackmagic-design.com/support/software/
    Windows should have some kind of log located in:
    C:\Documents and Settings\All Users\Application Data\Microsoft\Dr Watson.
    There should be a text file called Drwtsn32.log
    Please delete the file, attempt to replicate the problem again and if you succeed, the file will be re-created. Please send this file to us via our support email address: support[at]blackmagic-design.com
    Thanks.
    regards
    Kristian Lam
    Blackmagic Design
  • Adrian Tecson
    November 23, 2006 at 4:24 pm
    I’ll try that Kristian. Thanks
