Activity Forums Maxon Cinema 4D framecount display in renders
  • framecount display in renders
    Posted by Dennis Van den bergh on February 7, 2009 at 1:01 pm
    Is it possible in C4D to display the framecount/timecode in the renders, maybe in one of the corners of the frame?
    Duno where to search for this, in the form of plug-ins? Or can this be done within c4d core?
    If it is, i certainly hope it does not involve any coffee-scripting.
    suggestions welcome
    D
    Dennis Van den bergh replied 17 years, 7 months ago 3 Members · 3 Replies
  • Sascha Verwiebe
    February 8, 2009 at 7:42 pm
    in the viewport you are rendering choose:
    Edit/Configure../ under the HUD tab tick “Frame Time” and/or “Frame”
    then select “Render HUD” in your render settings
    sascha
  • Randy Johnson
    February 8, 2009 at 7:58 pm
    I find that on broadcast preview monitors the HUD renders are hard to read so I use an extruded text object and in xpresso I take a time node (choose frame) and plug that into the Text objects “text” option then you can control the size.
    /Randy
  • Dennis Van den bergh
    February 9, 2009 at 9:46 am
    Thank you so much Randy & Sascha!
    This definitely will help reduce superflues computing in the final renders 🙂
