Activity Forums Avid Media Composer Frame-View Question
  • Frame-View Question
    Posted by Adam White on February 10, 2013 at 8:53 pm
    I’m fairly new to Avid and have noticed a few little things whilst working on it that I could perhaps be doing more efficiently.
    In FCP, I make heavy use of the “good” column, ticking any clips that are of particular note. Doing so helps me quickly whittle down the shot choices when it comes to editing. Obviously in FCP, I can have the “good” column and thumbnails on display at the same time.
    So my question is, what would be a similar solution for Avid? I want to ideally have thumbnails and an indicator showing clips I marked as good within the same view. So far in Avid I have been either marking clips I consider “good” in green or ticking a custom column I made for “good” clips. This is fine in Text view, but when I switch to Frame-view (as sometimes I will as it’s easier to see what I’m looking for) this information of what clips I marked “good” isn’t on view anywhere. Is there a different setting somewhere that could remedy this?
    Many thanks in advance.
    Oliver Peters replied 13 years, 6 months ago 3 Members · 2 Replies
  • Jeff Greenberg
    February 10, 2013 at 8:59 pm
    What if you looked your footage in script view and then added comments on good or not?
    In List view, you can add a “Frame” in column view – just like FCP
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
  • Oliver Peters
    February 11, 2013 at 9:08 pm
    Another option is to use Custom Sift. Go through a bin in list view. Create a custom column and add an “x” by any clip that you want. Use Custom Sift to filter for “x” in that custom column. Then view the bin in list, frame or script view. Show Unsifted to see the full contents of the bin again.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
