Activity Forums Media 100 Frame Stuttering.
  • Frame Stuttering.
    Posted by Chris Clephane on December 9, 2008 at 5:22 pm
    AFter Effects CS3. Media100 HD AJA Kona 3 HW. 9 GB RAM.
    OSX 10.5.5 QUICKTIME 7.5.5
    I am having a problem that has popped up intermittently in the past (Since CS3 was released)…PREVIOUSLY I thought it was me or the system install….now I know better (fresh install). I definitely have a problem.
    Footage captured currently and previously into the Media100HD codec is giving me fits in AE CS3.
    I have enabled/disabled multiprocessing and Griiron Nucleo…my suspected culprits. No affect. (It looked like a werid cache issue…but cleaning database and purging caches has no effect.)
    SYMPTOMS: upon preview and render any footage captured in the Media100HD codec displays several frames (100-300 frames) correctly….in order…then randomly “jumps backwards” for a frame or …then corrects. Temporal audio sync is never lost…and there is NO audio glitch associated with the video “jump”.
    – This happens on previews AND renders in AE.
    – This happens with footage brought in by XML import or FILE-DRAG import.
    – The footage plays/looks fine in the Media100 Application.
    – My drives are plenty fast (10 drive SCSI u320 RAID 0… speed= >500MB/s).
    – It only seems to be for footage that uses the Media100HD codec.
    – This happens with footage captured via our Kona 3 or HDx systems. Media100 codec is the common element.
    I have tried the whole 29.970/30 fps shuffling on the AECS3 project files…no affect.
    My only solution so far has been to redigitize into ProResHQ.
    Any thoughts? Co-misseration?
    Chris Clephane replied 17 years, 9 months ago 1 Member · 1 Reply
  • Chris Clephane
    December 18, 2008 at 8:50 pm
    Nevermind…its the Quicktime 7..5.5 issue.
    Unlike most…my footage at least PLAYS…it just RENDERS incorrectly.
    -C
    I edit video. I post sometimes.
    I fix things. I eat marshmallows.
    I play drums. I drink scotch.
    I like TV.
    Done typing now.
