Activity › Forums › Compression Techniques › Frame Skipping – Video and Audio Desync
  • Frame Skipping – Video and Audio Desync
    Posted by Nick Howard on March 10, 2010 at 4:29 am
    Hi
    We are having an issue with one of our video’s that was put together using Final Cut Pro https://www.youtube.com/watch?v=aoEQWkusj-w
    At different parts of the video the image stalls while the audio continues.
    Does anyone know what we can do to get rid of this stalling? Is it a setting/s that we need to correct when rendering the final video?
    The Mediainfo data is below. Thanks for your help.
    General
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 1 009 MiB
    Duration : 1mn 42s
    Overall bit rate : 82.3 Mbps
    Encoded date : UTC 2010-03-04 00:41:15
    Tagged date : UTC 2010-03-04 00:41:35
    Writing library : Apple QuickTime
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L5.0
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 1mn 42s
    Bit rate mode : Variable
    Bit rate : 80.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 1.543
    Stream size : 981 MiB (97%)
    Language : English
    Encoded date : UTC 2010-03-04 00:40:55
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : PCM
    Format settings, Endianness : Big
    Format settings, Sign : Unsigned
    Codec ID : in24
    Duration : 1mn 42s
    Bit rate mode : Constant
    Bit rate : 2 304 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 24 bits
    Stream size : 28.2 MiB (3%)
    Language : English
    Daniel Low replied 16 years, 6 months ago 2 Members · 1 Reply
  • Daniel Low
    March 11, 2010 at 11:04 pm
    [Nick Howard]
    “Format profile : Main@L5.0
    Format settings, CABAC : No “
    Why no CABAC?
    I’d say High @4.1 not Main @5.0
    “Main Profile (MP)
    This profile is used for standard-definition digital TV broadcasts that use the MPEG-4 format as defined in the DVB standard[24]. It is not, however, used for high-definition television broadcasts, as the importance of this profile faded when the High Profile was developed in 2004 for that application.”
    What’s the GOP size?
    What are your VBR settings? (Average, low and upper)
    Sent from my iPad Nano.
