Activity Forums Adobe After Effects frame skip?
  • Pierre Jasmin
    December 20, 2015 at 5:30 am
    Looks like you are not nesting to make the sequence longer
    https://help.revisionfx.com/album/20/
    Pierre
  • Pierre Jasmin
    December 21, 2015 at 6:03 pm
    Also if you are animating by expanding the video track and selecting motion | Twixtor Output: Speed to show up as a curve, try a non linear interpolator (It defaults to linear). You can access the curve types by right-mouse clicking on a keyframe. Make sure the curve does not go backward though which is easy to do if you look at it real small…
    Pierre
