Activity › Forums › Apple Final Cut Pro Legacy › Frame Size mismatch between import and capture xdcam ex
  • Frame Size mismatch between import and capture xdcam ex
    Posted by Vince Gaffney on January 22, 2008 at 10:58 pm
    I’m trying to find the best method to down convert Xdcam ex footage shot at 1080i. I captured it with my Kona LHe via SDi and down converted there. It looked great. I imported it from the SxS card into the SD project I created for the capture and when I drop it in the sequence it’s a bit squeezed looking. I’ve tried a million little things and fear I’m missing something , well, simple. Any ideas?
    Vince
    Vince Gaffney replied 18 years, 8 months ago 3 Members · 4 Replies
  • David Roth weiss
    January 22, 2008 at 11:13 pm
    Try loading into the viewer and click on the Motion Tab and change “distort” setting to “0.”
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Vince Gaffney
    January 22, 2008 at 11:37 pm
    Thanks David. It already is set at 0. That’s the part that’s a weird to me.
    vince
  • John Pale
    January 23, 2008 at 3:13 am
    Full Raster HD Pixel Aspect Ratio is square. SD video is D1 (non-square). Could that be what you are seeing?
    Can you change it in clip properties?
  • Vince Gaffney
    January 23, 2008 at 3:19 am
    I believe that is the problem. I need to start the entire process again and make sure everything is set properly at the start. I realized once I opened it in Combustion. Thanks for the help.
    vince
