Activity › Forums › Boris FX Particle Illusion › frame size issue
  • frame size issue
    Posted by Emmet Reddy on May 26, 2009 at 11:24 am
    Hi I have just started using particle illusion and getting the correct frame size is a bit strange, i need it to be 1920 bye 1080 i have set this in project settings but when i want to save the movie the output size says limited to stage window so i zoom in to get the size i want, but when i open my movie a large part of it is cropped out, i just want my movie to be 1920 bye 1080 ive done it before, but now i think im doing something wrong any advice?
    Thanks Emmet
    Alan Lorence replied 17 years, 4 months ago 2 Members · 5 Replies
  • Alan Lorence
    May 26, 2009 at 2:46 pm
    Here’s what you need to do if you’re using particleIllusion 3.0:
    1) Make sure you’re using the latest version
    2) Maximize the particleIllusion app window to fill your desktop.
    3) Set stage size to 1920×1080 in project settings dialog
    4) Make sure stage zoom is set to 100% when ready to render
    5) pIRender will launch automatically if pI3 can’t render a size that big itself.
    If you’re using particleIllusion SE, steps 1-4 are the same, but step 5 is:
    5) Manually resize the stage window so it is large enough to fit the entire stage area at 100% zoom. If your desktop resolution isn’t high enough to do this, then you can’t render 1920×1080 with SE.
    Alan.
    http://www.wondertouch.com
  • Emmet Reddy
    May 27, 2009 at 10:34 am
    Hi its me again, when you say render, i assume you mean save output?
    I have done what you said i am using Particleillusion 3 not se and when i select make movie im zoomed in at 100% i have set stage on view as full screen i select save movie but it only goes to 1852×964?
    What am i doing wrong?
    Im working with two cinema apple cinema displays with a resolution of
    1608×1050
    Thanks Emmet
  • Alan Lorence
    May 27, 2009 at 7:36 pm
    Please check the version number. I’m pretty sure you’re not using the latest version. If you were, pIllusionRender would launch to handle the large output resolution.
    Alan.
  • Emmet Reddy
    May 29, 2009 at 11:42 am
    My version is 3.0.1
    I just want to check ”PI SE does not allow blocker, yes? My version has the blockers so i should be able to render at the frame size i want?
    Anyway, I have converted my footage to 1024-576 and i can get PL to work for me at this frame size, so until i can figure out how to get the larger frame size to work, i will move on with some dismay to the smaller frame size, However if you have any other suggestions let me know.
    Thanks Emmet
  • Alan Lorence
    May 29, 2009 at 2:05 pm
    3.0.4.1 is the latest. Check the “updates” section of the “downloads” page on our website.
    Alan.
