Activity › Forums › Apple Final Cut Pro Legacy › Frame size adjustment
  • Frame size adjustment
    Posted by Jim Mcnally on July 27, 2007 at 4:20 pm
    I am creating a 600×240 frame size file in motion with a .9 aspect ratio. In FCP I prepare my sequence as a 600×240 frame size with a .9 aspect ratio. When I import the motion file into FCP I am getting a letterbox on top and bottom. The only way I can fill the frame is to adjust the scale without constraints.
    I was expecting that I could drop the file in and it would fit because everything was created the same.
    Can anyone suggest what might be the cause of the letterbox?
    thanks,
    Jim McNally
    Jim Mcnally replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
