Activity Forums Adobe After Effects Frame Recreation / Pixel-Motion Problem
  • Frame Recreation / Pixel-Motion Problem
    Posted by Max Weissenbacher on August 30, 2011 at 1:57 pm
    Ok, as already mentioned, I’m having a problem with recreating some (exactly 50%) “missing” frames, or otherwise with Pixelmotion. So the problem is: how do I recreate 50% of all frames (my source footage was scanned/imported by FCP at 25fps, but in fact is 12.5 fps, so every frame is repeated twice at these 25fps) using Pixelmotion in AE CS5.5?
    What I tried already is to have AE play the footage at 200% speed, then precomp that and have that precomp play at 50% speed, so I then had 100% again. I couldn’t “loose” any frames, as although this method only leaves you with 12.5 frames (not per second, because it’s playing at 25 fps but only with 12.5 frames, right?), I already started with only 12.5 fps. However, when I then tried to apply Pixelmotion and turned it on in the comp, it didn’t work! Maybe my idea to combine a change in time (so AE will be able to apply Pixelmotion) and having the footage play at 100% didn’t work or doesn’t make sense, HELP PLEASE!
    Thank you very much in advance!
    Cheers,
    Max
    Max Weissenbacher replied 15 years ago 3 Members · 3 Replies
  • Ben G unguren
    August 30, 2011 at 6:27 pm
    If I’m understanding correctly, you need to render your images out of AE at 12.5fps (so you only have one image at a time, instead of two repeating images). Then reimport that, interpret the footage for 25fps, drop it into a comp, double the comp’s duration, apply Timewarp, set the speed to 50%, etc etc.
    But the key, I think, is to pre-render the 12.5 fps movie.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Rousselos Aravantinos
    August 30, 2011 at 6:28 pm
    hey at AEScripts u can find two very useful scripts for AE:
    1. Duplicate Frame Remover
    https://aescripts.com/duplicate-frame-remover/
    2. FrameRestorer
    https://aescripts.com/pt_framerestorer/
    for frame restorer i think twixtor will do a better job compared to timewarp, So just copy paste those keys to twixtor.
  • Max Weissenbacher
    August 31, 2011 at 1:00 pm
    Thank you very much for your responses! I will check those two (three) methods out now!
    Cheers,
    Max
