Activity Forums Adobe After Effects FRAME Rate
  • FRAME Rate
    Posted by Tim Hook on March 10, 2009 at 6:19 am
    Okay, so I was up late working on a project doing some composite shots. In the wee hours, I accidentally did on of the comps at the wrong frame rate, so now it’s all jittery.
    The original source is DVCPRO-HD at 23.976, however I did all my keyframing (rotoscoping) in a 29.97 timeline. When I change the comp back to 23.976 from 29.97, all my keyframes are off, and in-between frames. I’m trying to keep from re-animating all my masks, frame-by-frame again. I tried to just render it out as 23.976 but it doesn’t playback smooth in the FCP sequence, and I tried to do a reverse telecine on the original 29.97 render, and didn’t have any luck…
    Anybody got any ideas? I mean if I have to spend all night re-doing it, so be it, but I’d rather not, I would like to get some sleep at some point.
    Thanks in advance!
    Tim Hook replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
