Activity › Forums › Adobe After Effects › Frame rate standards for animation?
Posted by Trung Nguyen on January 13, 2012 at 6:17 pmHere’s the situation…
The project I created is an audio react one using Trapcode Form, Particulars, PSD images, etc. There are no video footages. All compositions were created at 29.97 frame rate (which I’m not sure is correct for my animation or not).
I was wondering, is there a standard frame rate for animation? And which is better for animation like this: 29.97 or 23.976, or others?
Walter Soyka replied 14 years, 8 months ago 4 Members · 6 Replies -
Kevin Reiner
January 13, 2012 at 6:45 pmWhere will your animation be used? Web, TV, film release etc?
Mac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23″ flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig -
Trung Nguyen
January 13, 2012 at 6:59 pmIt will be uploaded to Youtube and for viewing on computers only.
Michael Szalapski
January 13, 2012 at 7:35 pmFor YouTube, I’d stick with standard frame rates. 29.97 should be just fine.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Kevin Reiner
January 13, 2012 at 7:54 pmUse 30 fps. Someone correct me if I’m wrong, but I believe that is the max for youtube. 24 fps is if you wanted to go to film (you might get a judder problem with some animations if at 24 fps). Wikipedia gives a pretty good overview of it all. For web use, 30fps is pretty standard.
-Kevin
32GB Memory
ATI Radeon HD 5770
Rourke 16 TB
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig -
Trung Nguyen
January 13, 2012 at 11:04 pmOk another question about frame rate in general:
When is it a good time to use 23.976 and when is it better to use 29.97? Please give some examples.
Kevin, can you give some examples of what you mean by going to film? As in trailers or commercials?
Walter Soyka
January 14, 2012 at 1:44 am[Trung Nguyen] “When is it a good time to use 23.976 and when is it better to use 29.97? Please give some examples.”
Frame rate is generally more a technical choice than an artistic one.
Which to use? That depends on your deliverable. You should try to match the native frame rate of your intended display.
When your display supports a number of frame rates, you should try to match any imported footage you might have. There’s no sense animating at 29.97 if all your footage is 23.976.
23.976 fps is traditionally used for cinematic display, but many people foolishly equate a low frame rate with high production values. Animating in 24p can be much more challenging than 30p, because it’s much, much easier to get unwanted strobing or judder on quickly-moving objects.
23.976 is useful for multi-standard delivery. In addition to native 23.976 or conformed 24.0 playback, you can conform a 24p animation to get to 25p (speeding it up slightly) for European display or other 50 Hz areas, or you can add 2:3 pulldown to get 29.97i or 59.94p video in the US or other 60 Hz areas.
Walter Soyka
