Frame Rate Problems on PS3 Playback of Vegas Files
I’m encountering problems creating BD discs from Sony HD camcorder files for play on the PS3. I’m using Vegas Platinum 9.0 on Windows XP.
The .m2ts files on my discs will play fine for the first 15-16 minutes, then have terrible frame rate issues (choppy, stuttering video, sometimes briefly sped up) for the remainder.
Here’s what I’m doing: The original .m2t clips are compiled into .vf files, rendered as Sony AVC files with default options. (PC limitations prevent the creation of files larger than 30 minute runtime.) I then use Nero 8 Burning ROM to create a UDF BD compilation of multiple .m2ts files.
The PS3 shows the discs as “Data” under the Video menu. I’ve tried two PS3 consoles, including a brand new unit, and the problem occurs on both. What am I doing wrong? Many thanks!
