Activity Forums Adobe After Effects FRAME RATE PROBLEM
  • FRAME RATE PROBLEM
    Posted by Stephen Lubin on August 15, 2007 at 1:29 am
    Hi all, When I render a clip on after effects with a rate of 24 fps, I then try to upload the clip to Encore DVD, where I get an error message of: “Could not import such clip, Video files for this project must have a frame rate of 24 or 29.97 fps.”
    So I’m confused, because i set it to 24 fps, yet its not rendering in 24 fps?
    PLEASE HELP!!!!
    Stephen Lubin replied 19 years ago 2 Members · 5 Replies
  • Steve Roberts
    August 15, 2007 at 1:21 pm
    Can you set up your comp for 23.976 fps, and render that?
  • Stephen Lubin
    August 15, 2007 at 3:47 pm
    I’ll see if I can do that and let you know, thanks!!
  • Stephen Lubin
    August 15, 2007 at 6:05 pm
    Well, I tried the 23.96 fps and that didn’t work, do you know as to why this is happening?
  • Steve Roberts
    August 16, 2007 at 4:28 pm
    Check the clip in Quicktime Player (cmd+I) to check its frame rate. If it is indeed 23.976 fps, you should post in the Encore forum.
  • Stephen Lubin
    August 19, 2007 at 3:18 pm
    It worked!! Thanks a lot!!!!!! 🙂
