Activity › Forums › Apple Final Cut Pro Legacy › frame rate problem
  • frame rate problem
    Posted by Damir Ocko on January 30, 2009 at 11:50 am
    Hy all,
    hope somebody can help me with this problem, I am quite fresh FCP user so…
    I am editing at the moment and I am stuck with a problem I
    cannot solve even with solutions I read on forums.
    Here it is:
    The video was shoot on sony z7 HD 1080i progressive but the problem is on
    the same tape (sony HDV, DV mini DV) I have 25fps and some parts on 50fps (some fast light shoots)
    i worked with 25fps with no problem and my sequence is set on
    1440,1080 proress422 HQ
    The problem is with 50fps parts.
    it always capture this on 25fps and it is a very bad quality.
    is there a way to do this on this sequence at all or I should do this some other way?
    Thans
    Damir Ocko replied 17 years, 8 months ago 4 Members · 4 Replies
  • Rob Grauert
    January 30, 2009 at 2:20 pm
    hmm. I’ve never tried to mix frame rates before, but if I were in your shoes my instincts would tell me to take the 50fps footage into Compressor and export it as 25fps. Make sure you activate the frame controls pane and select the proper options to achieve the best quality.
    If you have a Kona3 card, I think it can do the conversion in real time.
    Robert J. Grauert, Jr.
  • Jerry Hofmann
    January 30, 2009 at 2:21 pm
    50i is 25 frames, composed of 2 fields per frame.. it’s 50 fields and 25 frames. So capaturing it should result in 25 frames per second.
    Are you capturing the HDV as ProRes instead of native HDV? If so, edit in ProRes sequence setting. But if you’re capturing it AS HDV, then don’t do that… instead RENDER to ProRes changing the setting in the HDV sequence’s settings. You’ll find this in the Video Processing Tab of that sequence’s settings opened by selecting it in the Browser and typing cmd+zero.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Rafael Amador
    January 30, 2009 at 3:00 pm
    Hi Damir,
    Your message is a bit messy for me.
    What you mean, that some i50 footage have been captured as p25?
    Is your sequence i50 or p25?
    Check the i50 footage as Upper-first in the Browser.
    If you drop it in a p25 sequence you need to de-interlace it.
    Rafael
    http://www.nagavideo.com
  • Damir Ocko
    January 30, 2009 at 4:44 pm
    My sequence is set as
    HD 1440×1080
    Field dominance none
    Editing timebase 25
    compressor apple ProRess 422 (HQ)
    Problem is different frame rates on the tape that i cannot capture right For 25fps it works just fine but not with the 50 fps. (it captures everything as 25fps).
    Capture preset is set on HDV-apple ProRess 422 (HQ)
    Device control preset is HDV FireWire 50fps (in this case)
    Perhaps I should also mention that I am capturing from HDV mini deck.
    On the tape I have 1080i progressive 25fps and 50fps combined.
    Hope this bring some light in my problem.
