Activity › Forums › Adobe Premiere Pro › frame rate problem
  • frame rate problem
    Posted by Marko Milosavljevic on April 26, 2013 at 9:32 am
    I have a problem with frame rate. I want to edit some videos in Premiere CS5 and there is two kinds of videos. One is 29.97fps and the other is 25fps. My question is what is the best frame rate settings for the final sequence?
    Thanx in advance
    Marko Milosavljevic replied 13 years, 5 months ago 5 Members · 11 Replies
  • 11 Replies
  • Tim Kolb
    April 26, 2013 at 11:30 am
    Is there audio on the clips that you need? (do they have to run at the original speed for this use?)
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Chris Tompkins
    April 26, 2013 at 12:39 pm
    Which do you have more of?
    What is your final deliver?
    Is the 29.97 ” i ” or ” p ” ?
    Chris
  • Marko Milosavljevic
    April 26, 2013 at 12:48 pm
    Well, I have about the same amount of both video types. And videos are shoot with different camcorders, and both should be progressive, although Premiere doesnt see them as progressive when I go to modify video. For 29,97 it said that it cant recognize field order, and for 25 it said that is upper or lower, now I cant remember. But I know that camcorders make them as progressive. What do you mean “final deliver”?
    Thank you for your fast reply
  • Kris Merkel
    April 26, 2013 at 1:14 pm
    What Chris means by “Final Delivery” is the specification of the file format and framerate of the video you are giving you client, or posting to YouTube ect.
    You have many options in PrPro and I would suggest in upgrading to at least 5.5 but preferably CS6 as you will be able to work with both framerates in one timeline.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
    April 26, 2013 at 2:33 pm
    audio is not important, Im not gonna use it. Video is only thing that I need.
    Thanx
    April 26, 2013 at 2:37 pm
    Well the final delivery should be something for YT, like H264. I didnt know that in CS6 you can work with different FPS on the same timeline. How is that working? What is final result?
  • Kris Merkel
    April 26, 2013 at 2:55 pm
    I believe that it works like this (Someone else may need to confirm as I am not in the application at the moment) Bring all clips into your timeline Mixed framerates and mixed formats, the Mercury playback engine does the heavy preprocessing so you can view your content, then conform on output through AME for your final file.
    Kris Merkel
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
  • Tim Kolb
    April 26, 2013 at 2:58 pm
    You can use multiple framerates on one timeline in CS5…any version of Premiere Pro since 2003 actually…
    The key is which adaptation is most acceptable…and it tends to be a judgement call to some extent.
    My earlier question had to do with you possibly modifying the framerate on one or the other set of clips depending on what the footage is…right click on the clip (or clips) in the project panel, and select ‘modify’ and change the interpreted framerate of the selected clips. My guess would be that the 29.97 stuff might be better at 25fps than the reverse…but I don’t know the footage.
    If you mix them the way they are without framerate interpretation, make one sequence with a 29.97 framerate and one at 25 and mix few clips and see which way you think it’s less wonky…
    TimK,
    Kolb Productions,
  • Al Jensen
    April 26, 2013 at 6:05 pm
    If the 29.97 is interlaced you could telecine it to 23.976 progressive and then speed it up to 25 with very little noticeable difference in playback.
  • Chris Tompkins
    April 26, 2013 at 6:38 pm
    Try running a test.
    Create a sequence matching one of them. Drop a clip from the other format in there, export a clip, check it out.
    Chris
