Activity Forums Apple Final Cut Pro Legacy frame rate of quicktimes doesn’t match capture frame rate
  • frame rate of quicktimes doesn’t match capture frame rate
    Posted by Jason Watkins on September 19, 2012 at 11:05 pm
    Hello, capturing HDSDI with a Blackmagic card at “Blackmagic 23.98 Apple ProRes 422.” After capturing, revealing file, opening that file in QT and getting info, the frame rate does not equal 23.98. Instead I am seeing a wide range 23.88-23.99. The initial problem was that the frame rate was much lower–around 14-20fps. I believe that was due to a failing disk. After replacing the disk, I am now within the hundredths, but still not spot on. Is this usual?
    I have tried capturing to faster drives (an internal striped RAID), reinstalling FCP, and the decklink drivers.
    Still not getting 23.98 like we were before…
    Jason Watkins replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
