Activity Forums Adobe After Effects Frame rate manipulation
  • Frame rate manipulation
    Posted by Lewis Hackett on February 5, 2011 at 1:16 am
    Hey there, I am working on a project which requires some green-screen shot footage to be composited over old Archive footage to make it look like the actors are in the old scenes. I have matched everything correctly with colour correction and grain but I would like to simulate the same frame rate as the source footage.
    Unfortunately I do not have details of the original frame rates so everything is being calculated by eye, and the footage varies from 1853, 1898, 1946, 1948, 1951, and 1962.
    I have used re:vision twixtor before for altering frame rates but I was wondering if there is a simpler or easier solution for dropping frames without using plugins?
    Any help would be gratefully accepted, and unfortunately I cannot post the video sources as they are licensed.
    Cheers, Lewis
    Lewis Hackett replied 15 years, 7 months ago 2 Members · 2 Replies
  • Simon Bonner
    February 5, 2011 at 1:28 pm
    Put your original footage into a precomp, lower the frame rate in that comp, then go into the Advanced composition settings (Composition > Composition Settings), and choose Preserve Frame Rate When Nested Or In Render Queue. I think this will give what you need.
    Simon Bonner
    youtube.com/simonsaysfx
  • Lewis Hackett
    February 8, 2011 at 3:01 pm
    Thankyou Simon, that is exactly what I was looking for 🙂
    Lewis
