Activity Forums Apple Final Cut Pro Legacy frame rate issues
  • frame rate issues
    Posted by Peter Giffen on December 15, 2009 at 7:03 pm
    I have been handed a finished timeline, that has 24fps footage and 59.94 footage in the same timeline, it looks fine in the viewer window but when I export at current settings to qt it gives me grief. Certain shoots (the ones that are 59.94 although not always) come out strobey or jittery. I assume it is a frame rate issue. Any quick tips on a fix for this.
    Thanks in advance.
    Peter Giffen replied 16 years, 9 months ago 2 Members · 4 Replies
  • Alan Okey
    December 15, 2009 at 7:23 pm
    What is the format of your footage?
    What are your sequence settings?
    Is the 59.94 footage 24p shot over 59.94 (i.e. 24p shot over 720p60 with a 3:2 cadence) or true 59.94 (720p60)?
  • Peter Giffen
    December 15, 2009 at 7:27 pm
    DVCPRO HD
    960×720, 23.98, dvcpro HD 720p60
    Honestly I am not sure
  • Alan Okey
    December 15, 2009 at 8:22 pm
    [Peter Giffen] “Is the 59.94 footage 24p shot over 59.94 (i.e. 24p shot over 720p60 with a 3:2 cadence) or true 59.94 (720p60)?
    Honestly I am not sure “
    Open one of the 59.94 clips in Quicktime player and step through the clip frame by frame. If the image changes every frame, it’s true 60p. If you see a repeating pattern of two duplicate images followed by three duplicate images, it’s 24p shot over 60p. If that’s the case and you want it to play nicely with the native 24p footage in the sequence, you’ll need to use FCP’s DVCPRO HD frame rate converter to remove the duplicate frames so that the 24p over 60p clips are conformed to true 24p.
    Although you can mix formats and frame rats in an FCP timeline and have it play back, it’s only meant for preview purposes. FCP doesn’t do proper format conversion for rendered output. You’ll need to conform all of your clips to one format and frame rate prior to editing for proper output without artifacts.
  • Peter Giffen
    December 16, 2009 at 1:44 pm
    Alan, Thanks very much, you may have saved the day, I will keep you posted, I like FCP and find it a fast to edit with issues like this make me love my avid.
