Frame rate issues on export
I’m trying to finish up a project, and have run into a problem.
I’m trying to export a sequence from FCP 5 in the Animation codec, 30 fps, millions colors+. It seems to export okay, but it is exporting at 13 fps. Same thing happens when I try it right in QT Pro.
I have no problems with exporting to the above settings in Motion, Shake, or Cinema 4D. Just FCP and QT.
The sequence settings are 720 x 486, 30 fps, Animation, as that is the format of the video clips I’m using.
Any ideas?
