Activity Forums Adobe After Effects Frame rate issues in my Master composition
  • Frame rate issues in my Master composition
    Posted by Lindsay Mccutcheon on June 6, 2019 at 3:23 am
    I have a 15000×1040 composition filled with 23.976fps animations. I need to scroll from one end to the other in a regular 1920×1040 composition in exactly 10 seconds.
    I keyframed the start and end position in a master composition, but as you can imagine the scrolling effect in 23.976fps was way too jarring to see any of the animation clearly.
    So I changed the master comp frame rate to 48fps, and the result was much smoother.
    My problem is this: I have a metric tonne of masks applied to all of these animations, which are all slipping when viewed in the master comp.
    As a work around I tried rendering out the 15000×1040 comp to pull into the master comp (not ideal), but AME crashes every time I try render it.
    Any ideas?
    Lindsay
    Lindsay Mccutcheon replied 7 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
