Activity Forums Apple Final Cut Pro Legacy frame rate issues
  • frame rate issues
    Posted by Jeff Carbonneau on February 1, 2010 at 9:52 pm
    Hope some can help me out with this. I’m edit a lot local car ads, and have just finished cutting my first spot in HD. For delivery, the tv station wants an MPEG2 29.97 frame rate on a data DVD. Fine. I’m cool with that. Here’s my issue though. Since I shot it in 24F on my XLH1, does that mean I should edit on a 23.98 frame rate native sequence to the shooting settings. Before my edit, I made my sequence 1920×1080 and 29.97 to accommodate the broadcast specs. And the 1440×1080 XLh1 (transcoded to prores) footage looks fine on a 1920×1080 pro res timeline. Although, when I create my MPEG2 1080 29.97, and play it back in Quicktime and VLC, there’s a major difference in frame rate from I’m just watching it back on my timeline. Like there’s a frame rate issue going on. It’s weird because the 23.98 prores footage on a 29.97 timeline looks fine on the playback monitor. Any help would be much appriciated…
    Rafael Amador replied 16 years, 7 months ago 2 Members · 1 Reply
  • Rafael Amador
    February 2, 2010 at 5:04 am
    Hi Jeff,
    In in Pal land, but if I’m not wrong, you should do your DVD in 23’98.
    The Pulldown is added on play to reach the standard NTSC (29,98).
    rafael
    http://www.nagavideo.com
