Activity › Forums › Adobe After Effects › Frame Rate in After Effects
  • Frame Rate in After Effects
    Posted by Steve Keele on August 31, 2009 at 2:59 pm
    I have rendered frames from Maya that I am importing into After Effects as a sequence. I want to have the base rate changed from 30 fps to 60 fps. I can change the composition Frame Rate to 60 but it just takes my animation frames and shows each one 2 times before moving on to the next frame.
    How do I change the Frame Rate of the sequence?
    Steve Keele replied 17 years ago 2 Members · 2 Replies
  • Todd Kopriva
    August 31, 2009 at 3:56 pm
    from “Change the frame rate of a sequence”:
    “When you import a sequence of still images, it assumes the frame rate specified by the Sequence Footage preference in the Import category. The default rate is 30 frames per second (fps). You can change the frame rate after importing by reinterpreting the footage item:
    Select the sequence in the Project panel, choose File > Interpret Footage > Main, and then enter a new value for Assume This Frame Rate.”
    More information about frame rate in After Effects is in “Frame rate”.
    I found this with this search of After Effects Help.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Steve Keele
    August 31, 2009 at 3:58 pm
    That worked. Thank you so much.
