Activity › Forums › Panasonic Cameras › FRAME RATE CONVERTOR FOR FINAL CUT DOESNT WORK
Posted by Chip Monk (hd tech) on August 20, 2005 at 3:06 pmI INPUT THE CLIPS USING THE DVCPRO100 CODEC AT 59.94 AND HIGHLIGHT THE CLIP IN THE BIN AND CLICK ON THE FRAME RATE CONVERTOR AND IT TELLS ME THE CLIP IS NOT A 59.94 DVCPROHD CLIP, ANYONE ELSE HAVE ANY PROBLEMS
Gary Adcock replied 20 years, 11 months ago 5 Members · 10 Replies -
Wayne Franklin
August 20, 2005 at 5:07 pmI just posted this in the FCP forum — I converted some files yesterday with the FRC, and they all worked fine. I tried to convert some clips today, and I got an error message saying there was no video in the selected clip. I even tried converting clips that were converted yesterday with no luck today.
What FPS was used when shooting your footage?
The cheese stands alone.
Dale Mccready
August 21, 2005 at 8:06 amnot sure this is appropriate but if the clips are in a separate cpature bin and not in the main project bin they will not be seen by the FRC plugin, they need to be at the top level.
Wayne Franklin
August 21, 2005 at 1:17 pmThat could be the ticket. Damn me and my need to organize!
Thanks, Dale.
Emily Thwaites
October 4, 2005 at 7:49 pmHi Dale,
I was able to convert my files yesterday with the Frame Rate Convertor and am
getting an error message today stating:The selected media file (101:2a%20%20%20WS%20Picks%) cannot be processed by this tool.
Only DVCPRO HD 720p 59.94 fps media files are supported.But my files were brought in via the easy setup DVCPRO HD 720p 60 48kHz
I don’t understand why it worked yesterday and not today. I’ve re-installed the components
and plugin from the panasonic website and restarted several times. I’ve taken the clips out of the
bins that I organized them into so that they’d be at the highest level and it still doesn’t work.
Any help will be greatly appreciated.
Thank you.Emily
Dale Mccready
October 4, 2005 at 8:26 pmWhen you shot with these files nothing was changed on the camera either?
Dale Mccready
October 4, 2005 at 9:19 pmWhen shooting, was the setting the same for everything? I’m just trying to ascertain whether anything could have changed in the files themselves rather than with FCP. Previously when you have been converting the files, they worked. Were they shot at the same time, on the same camera? Were they part of a larger batch?
Honestly it sounds like somethign strange in FCP, but also did you digitize these files seperately from the others?
Emily Thwaites
October 4, 2005 at 9:31 pmAll the clips are part of the same project.
The production team used the Varicam and
shot at 40fps & 60fps.
We did the test clips yesterday and once they worked
I began digitizing everything in. Perhaps it is
a FCP problem, although we have trashed the
preferences and re-installed the Frame Rate
Converter Plug-In.Emily
Dale Mccready
October 4, 2005 at 9:36 pmWhat a hassle,
Since the problem I had was a fickle folder management problem I’d look for something just as simple/weird to be the cause. Sorry I can’t be of more help.
Gary Adcock
October 5, 2005 at 12:27 pm[Emily Thwaites] ” was able to convert my files yesterday with the Frame Rate Convertor and am
getting an error message today stating: The selected media file (101:2a%20%20%20WS%20Picks%) cannot be processed by this tool.
Only DVCPRO HD 720p 59.94 fps media files are supported.”You can only use the Software FRC once on a file.
You can only use the Software FRC on DVCPROHD compressed content.
The Software FRC will only work on DVCPROHD content listed in the Browser window.
The Software FRC cannot see into subfolders, so if you have moved your content it will not convert.
The software FRC has difficultly and often will not process content that has bars and tone at the head.Gary Adcock
Studio37
HD and Film Consultation
Chicago, IL USA
