Activity Forums Adobe Premiere Pro Frame rate converter
  • Frame rate converter
    Posted by Erik Thrane on May 26, 2009 at 7:36 am
    I had some 8mm films scanned for a project. The were shot in 18 fps, but I had them scanned in 25 p (PAL) in order to avoid optical blending. Thus I had the original film scanned non-distructively.
    Unfortunately, if I reduce the speed to 72% (18/25) in Premiere Pro it can only accomodate the new speed by inserting blended frames or repeating frames.
    So I need a frame rate converter that can generate the missing frames (by interpolation) in order to achieve the right speed withoutquality loss. I downloaded and tried out MotionPerfect and Frame Rate Converter HQ, but it seems to me that both degrade the resolution terribly.
    Am I doing something wrong?
    I know that Andrew Kramer has created a converter for Adobe After Effects but I do not have that program. Is it the only/best way to go?
    Or, can somebody suggest a high-quality frame rate converter that I can download?
    Best regards
    Erik
    Erik Thrane replied 17 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jon Barrie
    May 26, 2009 at 9:08 am
    The problem with slowing down video is that the frames are probably interlaced, which will degrade the image more when slowed down.
    Slowing down Video or Film is never a great result.
    Did you get the cine done with the frame rate at 25fps on the film playback? if so you could get a half decent result by interpreting the video to 18fps.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Jeff Brown
    May 26, 2009 at 2:57 pm
    Try “Twixtor” or reTimer by re:visionFX. Takes time to render, but can produce very nice results.
    -jeff
  • Erik Thrane
    May 26, 2009 at 5:22 pm
    Yes I got the transfer done at a 25 fps playback (progressively), so there should be no problem with half/interlaced frames.
    I am an ameteur, so please explain what you mean by “interpret”?
    Best regards
    Erik
  • Eddie Lotter
    May 26, 2009 at 6:06 pm
    You can right-click on a clip in the Project Panel and tell PPro to interpret the clip differently.
    Cheers
    Eddie
  • Erik Thrane
    May 26, 2009 at 6:39 pm
    Hi Jeff,
    played around with a test installation of Twixtor, but it seems that exactly the frame rate converter does not function in PP – only in Ae.
    Am I wrong?
    Best regards
    Erik
  • Jeff Brown
    May 27, 2009 at 12:59 pm
    I thought it worked in Premiere, but I’ve never tried it myself. Only use it in Combustion.
    Double-check the help doc, there are some quirky application-specific working methods that may apply to Premiere.
    If you’re still stuck, reVision has always answered support questions promptly in the past.
    -jeff
  • Erik Thrane
    June 7, 2009 at 11:08 am
    Unfortunately, the frame rate converter in Twixtor is not supported for Premiere Pro. See this chart: https://www.revisionfx.com/content/products/twixtor/features/host_supported.html
    Is there really not a pluginn for Premiere Pro fo frame rate conversion?
