thanks guys. i watched your tutorial Shane, and then followed all of your advice. it once again worked as before with the New project. that sure is a wierd bug.
It also took me a while to figure out what i was doing wrong trying to get the slow mo to actually look slow mo. I was setting my “Recording Setup” “Rec Format” from 720P/24P to 720P/60P (i don’t use PN because i have FS100 and it doesn’t do that) thinking that was setting the frame rate to the Slow mo mode after i converted it-it never looked slow mo. Wellllll, now it seems like i know how to set it, but still don’t really understand “WHY”. If i always want 24P why would i ever then choose the 720P/60P in the recording setup? Getting it to work is at least the most important right?
So, as i understand it, i can keep the 720P/24P “Rec Format”, But then change the “Frame Rate” in the “Scene File” to 60Frames. Then import and do the frame rate converter as described above-Right? It seems i should always select Delete Duplicate frames-Right?
thanks for any other info or clarrifications-i really appreciate what you have already provided.
Jeff
