Activity Forums Apple Final Cut Pro Legacy Frame rate conversion yields non-sync audio
  • Frame rate conversion yields non-sync audio
    Posted by Gerret Warner on October 8, 2015 at 4:48 pm
    I feel as if I’ve solved this before, but I can’t remember how.
    I’m trying to add video diaries from a smartphone as 30fps MP4s to a ProRes 422 24fps timeline in FCP 7, but when I convert the files in Compressor the resulting videos have lost sync.
    Thanks for any help.
    GW
    Shane Ross replied 10 years, 10 months ago 2 Members · 1 Reply
  • Shane Ross
    October 8, 2015 at 5:00 pm
    OK…this being from a phone…30fps straight up? or 29.97? 30fps straight up converted might be an issue. Because 30fps is a non-broadcast frame rate. And your sequence is 23.98, right? not 24fps straight?
    Try MPEG STREAMCLIP possibly…although it’s not good at frame rate conversions. What I would do in your shoes is convert the footage to 29.97 ProRes…and import that. Avid does a good job of mixing frame rates properly.
    Shane
    Little Frog Post
