Activity › Forums › Panasonic Cameras › Frame Rate Conversion
  • Frame Rate Conversion
    Posted by Michael Manfredo on January 17, 2009 at 11:04 pm
    Hello,
    I am currently trying to convert some footage I shot at 60fps using Panasonic’s frame rate conversion plug in. In the past, I used a 1200a deck and it was on fcp 4.5. The deck was connected via firewire. Now I’m on FCP V.6 and I am using a 1700 deck that is connected to my FCP system via sdi and it is going through a kona 3.
    Any information would be much appreciated,
    Michael
    Peter Corbett replied 17 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    January 18, 2009 at 7:55 am
    AFAIK that plugin will only work with Firewire captured footage. The pulldown flags don’t come across an SDI connection.
    Noah
    Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
    Now featuring the Sony EX1 Guidebook,
    DVD Studio Pro and How to Light Interviews.
    https://www.callboxlive.com
  • Gary Adcock
    January 18, 2009 at 5:39 pm
    [Noah Kadner] “AFAIK that plugin will only work with Firewire captured footage. The pulldown flags don’t come across an SDI connection. “
    Not true.
    AJA’s products do allow for RP188 to stay embedded when capturing as DVCPROHD( only)
    AJA’s toolset also allow for direct removal of flagged frames on HDSDI capture to ANY codec supported on the card when using the correct capture settings.
    The description for this is in my IoHD article here on the Cow (listed below) but covers all AJA products.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Michael Manfredo
    January 18, 2009 at 8:30 pm
    Hello ,
    Thank You so much. The conversion happened through sdi but only to 29.97 or 23.98, not 59.98. I’m going to take a look at the article you referred me to, but first I wanted to send my gratitiude.
    Thanks again,
    Michael
  • Mike Zimbard
    January 19, 2009 at 3:23 am
    That conversion plug-in is now part of FCP. Set your Kona FCP easy setup to be 59.94 Varicam DVCPROHD. After your clip is captured, click on it and then select “Tools>DVCPROHD Frame Rate Conversion….” From there you can pick the frame rate you would like to turn the clip into. Hope this helps.
  • Peter Corbett
    January 26, 2009 at 1:39 am
    Does this also work if you capture playback via HD-SDI directly from the Varicam (as against a deck)?
    Peter
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
  • Gary Adcock
    January 26, 2009 at 2:40 pm
    [Peter Corbett] “Does this also work if you capture playback via HD-SDI directly from the Varicam (as against a deck)? “
    Yes,
    but a caveat….
    The IoHD can do this all day long without issue due to the fact it can read both the LTC and the RP188 TC at the same time.
    When capturing direct from the camera and trying to remove pulldown from a live stream with a Kona Card there are a couple of issues.
    1) because the card in your computer needs to understand where frames are being removed, when there is NO hard in and out points set – it will need to guess when to end the clip and cease deleting the flagged frame when you hit stop.
    This can cause the final few seconds of your capture to NOT have the flagged frames removed when working with Kona Cards – since the computer cannotpositively determine what to remove since there is no LTC- increase the capture length by 5-10 seconds and that should allow the computer to handle the content.
    2) some people think this is a replacement for getting a deck-NO- remember that without LTC stream that can be captured from the IoHD – all of your Kona Card captured clips will start at 00:00:00 (or your default)
    gary adcock
    Studio37
  • Peter Corbett
    February 6, 2009 at 5:31 am
    Thanks for that Gary. Much appreciated
    Peter Corbett
