Activity Forums Adobe After Effects frame rate change ??
  • frame rate change ??
    Posted by Mike Moncrief on October 18, 2008 at 7:59 pm
    Hello,
    Got a bit of a problem.. I rendered a quicktime using the animation codec out of a 3d program on a Mac( Lightwave 3d) And after a long render, I went to play the quicktime and it plays back like there is only 4 frames.. (210 frame were rendered out) when I look at the item properties on the file I see it says it the right lenght, but it rate is 3000 frames per second… I can scrub through and see all the frames are there .. just cannot get it to play back correctly.. So is there a way to change it to 29.97 frames per second ??
    Thanks for any help in advance..
    Mike Moncrief
    Richard Harrington replied 17 years, 11 months ago 2 Members · 1 Reply
  • Richard Harrington
    October 20, 2008 at 1:10 am
    You can wither intrepret properties in AE (Cmd+F) in Browser or adjust with QuickTime Pro
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
