Activity Forums Apple Motion frame rate change
  • frame rate change
    Posted by Mike Moncrief on October 18, 2008 at 8:14 pm
    Hello,
    Got a bit of a problem.. I rendered a quicktime using the animation codec out of a 3d program on a Mac( Lightwave 3d) And after a long render, I went to play the quicktime and it plays back like there is only 4 frames.. (210 frame were rendered out) when I look at the item properties on the file I see it says it the right lenght, but it rate is 3000 frames per second… I can scrub through and see all the frames are there .. just cannot get it to play back correctly.. So is there a way to change it to 29.97 frames per second ??
    Thanks for any help in advance..
    Mike Moncrief
    Noah Kadner replied 17 years, 10 months ago 2 Members · 1 Reply
