Activity › Forums › Adobe Premiere Pro › Frame per frame hickups / very slow scroll/scrub
  • Frame per frame hickups / very slow scroll/scrub
    Posted by Pat Tremblay on January 9, 2012 at 9:54 pm
    I’m currently cutting shots from VOB files (and also M4V) to make a demo reel and the arrow key to go from one frame to the next is extremely slow, I have to wait like 3 seconds for each time I try to move from one to the next. Scrolling at that slow pace rate is very annoying to say the least.
    Could this be due to the file being a VOB or M4V, or something else? It’s such a basic thing that I’d be surprised it’s a memory issue…
    (See signature for pc specs) The thing is supposed to edit smoothly HD files of much higher weight… Working with Premiere Pro CS5.
    HP Elitebook 8760w laptop. Windows 7 – 64 bit. Intel(R) Core (TM) i7-2820QM CPU @ 2.30GHz 2.30GHz, 8GB RAM – Quadro 3000M Nvidia graphic card.
    Pat Tremblay replied 14 years, 8 months ago 2 Members · 2 Replies
  • Jeff Pulera
    January 9, 2012 at 10:21 pm
    Hi Pat,
    Do you have a separate drive (internal or external) for video editing? The C: drive should not be used for media. Did you copy the .VOB file to the hard drive or are you trying to edit right from the DVD?
    I don’t think your Nvidia card was supported for Mercury Playback GPU acceleration until CS5.5, maybe you can do “the hack” to use it in CS5 to enhance performance?
    https://www.studio1productions.com/Articles/PremiereCS5.htm
    Jeff Pulera
    Safe Harbor Computers
  • Pat Tremblay
    January 10, 2012 at 2:39 am
    Hi Jeff! None of my files were on my C drive nor did they were coming directly from the DVDs. I had completely forgotten about the hack for the mercury engine, and thanks to you, it has solved the problem, now every is running slick! Fantastic!
