Activity Forums Apple Final Cut Pro Legacy Frame offset for recapture
  • Frame offset for recapture
    Posted by Frank Andersson on February 15, 2008 at 10:52 am
    I’ve got an offline edit timeline which has to be onlined in 10bit uncompressed. So far so good. After final scanning of reels the tapes arriving from the laboratory is 12 frames off compared to the offline edit. They admit the mistake and ask if we can recapture the tapes offsetting with 12 frames….can I?
    I tried almost anything in Capture Offset, Playback Offset – changing the values to +12, -12 etc etc. but nothing seem to make sence. Sometimes duration of a clip are longer after this offsetting in Device Control Panel, sometimes in/out points are different from the logged times, but not 12 frames different.
    So – my question is: is there some easy way to deal with a offset like this? It must have happened to someone else but me. I know I could add another 12 frames to the in/out points manually, but that would take me ages to re-enter that to 300 clips – and my assistant would quit if I asked him to do it!! ;o)
    Frank Buck
    .: Denmark :.
    Frank Andersson replied 18 years, 6 months ago 1 Member · 1 Reply
  • Frank Andersson
    February 17, 2008 at 9:28 am
    …anyone???
    Frank Buck
    .: Denmark :.
