Activity › Forums › Adobe Premiere Pro › Frame offset for external monitor (LED TV) out of sync Premiere Pro / Black Magic
Posted by Robin Haman on March 11, 2014 at 6:14 pmHello,
I’m running Premeire Pro cc though a Black Magic intensity pro out to a second program monitor on a late 2013 model Samsung LED TV. My problem is that the audio is in sync with the program monitor on my computer display but there is a slight picture lag (a few frames) on the LED 2nd monitor, so when screening with clients the sync is slightly off on the display they’re seeing. When using FCP 7 I can offset the playback on the computer display so both monitors sync up. I’ve tried messing with the offset in PP but it seems like I can only offset the 2nd monitor not the program monitor on the computer. I was just wondering if anyone has encountered this problem and if there are any solutions? Ideally to have both monitors in sync with the audio. I hope it all makes sense.
Robin.
Jonno Woodford-robsinon replied 6 years, 1 month ago 9 Members · 10 Replies -
Mark Vernon
April 10, 2014 at 3:16 amWe are having the exact same issue but with a BlackMagic Decklink Card.
Has been an issue since day 1. Have tried playing with offsets. On some occasions it has not been until a commercial is on air that we have realised it is out of sync, as we assumed the client monitor, using blackmagic hardware would have been correct, and that the delay would also been in the audio. Seems that is not the case. Any ideas on how to correct this or work around would be great! -
Matt Campbell
April 21, 2014 at 4:53 pmSame here. But using Premiere CS6. I too have a Decklink Studio Card. I have audio from the card to my Mackie 802 and I also have a loop back from my external FSI monitor out, back into the Mackie. Both are off by about 2-3 frames.
Its funny, because once I export a quicktime h.264 for reference, its spot on. Just not able to figure out how to fix in Premiere.
I’m was wondering if my external RAID was an issue, but getting speeds of 280mbps, it shouldn’t be.
Playback is 1080p29.97, fully rendered in timeline at full quality. Just don’t get it.
OSX 10.7.5 with a 3.39 Ghz Intel Core i7 on a built up Hackintosh
16 GB of RAM with OSX on SSD, (2) internal HDDs RAID’d 1 for project files and External RAID 5 for all project assets (media, GFX, stills, etc.)
BMD Decklink Studio 2, FSI BM210, KRK Rokit 5s, Mackie 802 -
Mark Tuson
July 14, 2014 at 12:35 pmHi Robin,
I am also have having similar audio sync problems running adobe premiere cc with a multi bridge pro 2 which sends sdi out to a hd link which connects to apple dvi monitor. Have tried various delay settings in the premiere playback panel but still not managed to sync up sound with pics.
Any tips you found useful would be appreciated.
Many thanks,
Mark -
Peter Garaway
September 11, 2014 at 9:20 pmHi Guys,
I wanted to see if you could provide more detail about what your problem is. You said you were having issues getting your monitors in sync. Can you tell me how exactly they were out of sync and what your hardware setup is? i.e. Video in Premiere’s Program monitor plays ahead of external monitor by 2 frames or audio in external speakers plays ahead of external video etc…
If you modify the offset settings for either Video and/or Audio what happens?
Thanks for your time,
Peter Garaway
Adobe
Premiere ProPeter Garaway
Adobe
Premiere Pro -
Trevor Asquerthian
September 12, 2014 at 6:57 pmI’m having a hard time understanding the playback offset in PPro too. (8.0.1 (21) build with BM 10.1.1 driver using the MiniMonitor with HDMI out to a Samsung TV).
Initial setup has the HDMI display video approx 2 frames later (due to TV processing and possibly miniMonitor processing) than the PPro Program Monitor Panel.
The offset for the ‘Blackmagic Playback’ video device then affects how long before first video is displayed via HDMI, but the delay HDMI/Program remains the same at 2 frames.
Adjusting the offset for audio has no effect whatsoever that I can see, either for Desktop Speakers or Blackmagic playback (both of which are spot on at 0ms).
Matt Campbell
November 24, 2015 at 4:41 pmI’ve recently upgraded to CC and, like you, have the same problem. If you offset the audio and/or video output device by how ever many MS, it makes the problem worse. It feels like the offset is backwards. My Program monitor is spot on with audio that is routed out of my Decklink Studio 2 card into a Mackie 802 and out to my KRK Rokits. And video out SDI out to a Flanders FSI.
However, when I mute Ch. 1 & 2 on mixer which is the direct feed from Decklink and engage Ch. 5-6, which is an audio loop out from my FSI Broadcast Monitor back into the Mackie, the sync is very close. But its still not perfect. So I changed the Audio Playback offset to about 100ms and its pretty good now.
The problem is always having to switch back and forth between the direct audio from Decklink, which sounds bright, crisp and awesome, to the mute those channels and engage the loop, which doesn’t sound nearly as good because the audio out is 1/8″ stereo jack splitter to 1/4″ plugs into the Mackie.
Not a deal breaker, just an annoyance.
iMac 3.5 Ghz Intel Core i7
16 GB of RAM, NVIDIA GeForce GTX 780M 4096 MB
External RAID 5 in T-Bolt Chasis using eSata
Josh Thomson
January 27, 2016 at 8:33 pmI have the same 2 frame issue.
The audio is 2 frames behind, so I need to delay the vision by 2 frames (in my case 80ms)
Delaying the Blackmagic audio in Premiere’s but Blackmagic Playback offset (video) does not work.
iMac 27 inch. PPro CC 2015.
BM Desktop Video 10.5.4
BM Intensity Extreme and Mini Monitor – both at 2 frame delay.Any help would be amazing.
Word.
Josh Thomson
February 8, 2016 at 8:39 pmHas anyone in this thread had any luck?
Our BM works with Avid and FCP7. Just not in Premiere
After trying everything we are looking to change up to an AJA, but were hoping we wouldn’t encounter the same issue.
Word.
Martin Hickford
March 14, 2016 at 12:37 pmWow. Two years later and Adobe STILL haven’t addressed this issue? What a huge surprise. They’re normally so good at fixing bugs and mistakes *he said sarcastically*
Martin Hickford | Freelance Video Editor & Multimedia Designer for TV, Film, Commercial & Promo. Technically an adult.
https://www.shootfirsteditlater.com
August 4, 2020 at 6:31 amMake that 6 years later!
Film Editor: Avid, FCP, Lwks
Also dabble in VFX: Shake, Nuke
http://www.fusspotfilms.com
