Activity Forums Adobe After Effects Frame Number Speed Up
  • Frame Number Speed Up
    Posted by Pat Bray on November 4, 2008 at 3:16 pm
    Hi
    I’ve used the frame number expression and was wondering if there was a way of speeding it up so its perhaps, 3 times faster?
    Jon Ward replied 14 years, 4 months ago 4 Members · 6 Replies
  • Roland R. kahlenberg
    November 4, 2008 at 3:46 pm
    It may actually be more productive if you posted the Expression here.
    Cheers
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Pat Bray
    November 4, 2008 at 3:58 pm
    Sorry, the expression I’ve added to the source text is:
    timeToFrames()
    I thought that if I somehow added a multiplier to it, it would speed up the counter….?
    November 4, 2008 at 4:11 pm
    Hehe. I can’t help out with the Expression but you should be able to TimeRemap the bugger. Also, setting your fps to a higher rate may help.
    HTH
    RoRK
  • Pat Bray
    November 4, 2008 at 4:52 pm
    fps…. genius, thanks for the tip! (doh, should’ve thought of that!)
    Cheers
    Pat
  • Kevin Camp
    November 4, 2008 at 6:44 pm
    if you wanted to do it with an expression, you were correct, you would just add a multiplier… 3 times faster, just multiply by 3:
    timeToFrames()*3
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jon Ward
    April 26, 2012 at 9:28 am
    Hi
    How would I edit the expression to make the numbers begin and end at certain values?
    e.g. i’d like the expression to start with the numbers ‘800’ and finish at ‘999’.
