Activity › Forums › Adobe After Effects › Frame moving
Frame moving
Posted by Andres Fernandez on October 24, 2008 at 6:29 pmHow can I make this better? The picture is add it in After effects
test frame moving from Andres Fernandez on Vimeo.Andres Fernandez replied 17 years, 11 months ago 2 Members · 6 Replies -
Scott Novasic
October 24, 2008 at 8:56 pmI would have the picture card move more randomly, in more of an S curve type path. I would also definately have it rotate more in the xy and z axis. If I was making the settings I would have the card rotate (and you can shuffle these numbers around on any of the 3 axis) roughly
x – 550 – 0 degrees Y – 400 to 0 degrees Z – 140 – 0 degrees
have this happen over a slightly longer period of time than you presently have. Definately use motion blur and have all the values
ease in to the 0 degree settings. I think extending the effect a little
and keeping the card in screen will look better. Having the motion and rotation ease in at the end will be subtle but allow for the card to still fly out of the mans hands very rapidly and realistically. The ease in at the end is stylizing the motion, but would look better.I just finished a job with motion similar to this in it, so the numbers and look are pretty fresh in my mind.
good luck, looks like nice footage as well.
SuperNova
Animation & Visual Effects
Scott Novasic
Los Angeles Ca
web:https://web.mac.com/finaleffects -
Andres Fernandez
October 24, 2008 at 9:25 pmMmmm that is interesting I will try it. I was thinking also of a sore of shaking and moving down after it hits the lens Thanks
Scott Novasic
October 24, 2008 at 10:06 pmif you have it sort of “slap” onto the lens, and then slide down a little
I would eliminate the ease in at the end then.SuperNova
Scott Novasic
Los Angeles Ca
Andres Fernandez
October 24, 2008 at 10:45 pmyeah i know i don’t want the pic to land like a feather cuz he is not happy. What do you think about this. Thanks for all your help;}
Untitled from Andres Fernandez on Vimeo. -
Scott Novasic
October 25, 2008 at 1:40 amwell, i wrote a long response to you, and my machine\internet crashed.
aarrgggghhh.anyway. I love the new motion! Im not a fan of the last motion after it hits the lens however.
Briefly, I, personally, would have the picture “stick to the lens” at roughly a 5-10 degree angle. Leaving just a slight amount of the background showing through, so the illusion of an actual card sticking to the ‘actual’ lens is there while the scene with the woman plays.
You may have to slightly crop the video, but not enough to matter in my opinion. Id also put a white relatively thin edge around the picture card, which, to me, would sell the fact that he threw a card\photo nicely. lastly I would put a slight shine on the “lens” with the card on it, when the card hits. Id fade that shine out over 60-90 frames.just my opinion, worth what you paid me for it 🙂
SuperNova
Scott Novasic
Los Angeles Ca
Andres Fernandez
October 25, 2008 at 4:03 amwow nice ideas thank you very much. i will post some thing trying your ideas. Cheers From NYC
Check this out is Awesome
Just to have the links now all together:
https://www.barbecue-design.de/tutorials … ial_01.mov
https://www.barbecue-design.de/tutorials … ial_02.mov
https://www.barbecue-design.de/tutorials … ial_03.mov
