  • Posted by Matt Love on June 19, 2011 at 5:20 am
    I have a project I shot in 4:3 hdv and edtited in dv ntsc, and also captured in this. I exported as a quicktime ntsc. A few spots in my sequence I freeze framed a shot, and then faded to black. When watching the export ,the spots where I used the effect Im seeing a frame “jump” almost like its resizing. Any ideas why ?
    Matt
    Matt Love replied 15 years, 2 months ago 3 Members · 3 Replies
  • Jeff Greenberg
    June 19, 2011 at 8:39 pm
    Hard to say. What version of FCP? Where are you seeing the jumps? FCP? The export? If it’s the export, how did you get it out of FCP and which format/codec.
    For example, The Animation codec isn’t really meant for playback – and may appear to jump when it has all the frames.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Dan Mansfield
    June 20, 2011 at 2:39 pm
    I’ve seen this issue before when your footage codec doesn’t match your sequence codec. Select the item properties of both the clip and the sequence, if the compressor settings are different it could cause your footage to jump during simple effects.
    If that is the case, you should be able to change the compressor settings in the “Sequence Settings” tab (select the sequence and press Command-0) to match your footage. While you are there, make sure your editing timebase is the same as your footage. If they differ, create a new sequence with a timebase that matches your footage.
    Add your effects and it should render out without the “jump.”
    If you still have an issue, go into the Video Processing tab of your Sequence Settings and change the “Motion Filtering Quality” to Best.
    Hope that works for you!
    Dan Mansfield
    Point7West
    http://www.point7west.com
  • Matt Love
    June 20, 2011 at 3:38 pm
    Tx for the replies. After replaying in a different program it was fine..
    Matt
