Activity Forums Apple Final Cut Pro Legacy Frame Flicker Problem
  • Frame Flicker Problem
    Posted by Meesta Joe on August 11, 2006 at 1:08 pm
    I’m not sure what the cause is, but lately when I digitize from my Beta SP (UVW 1800) with vis Timecode Burn-in through my Aja Iola, I see Timecode from two consectutive frames supperimposed on each other. I’m not sure if it’s due to a Quicktime Update, FCP Update or what. This never used to happen. It doesn’t happen on my Computer- only on my external Monitor.
    I’m using FCP 5.1, QT 7.1 with Aja Iola 2.1 (This is what Aja recommended to use with my setup) and a G5 Dual 2G
    Any suggestions?
    Thanks in advance!
    Meesta Joe replied 20 years, 1 month ago 2 Members · 2 Replies
  • Tom Matthies
    August 11, 2006 at 1:27 pm
    Could you possibly be capturing with the fields in the wrong order? That would explain seeing two different TC numbers on the same frame. Each field is showing a different number. This will only show up on your external monitor. Is your Beta deck locked to the same reference as your IoLa?
    Tom
  • Meesta Joe
    August 11, 2006 at 4:18 pm
    “Could you possibly be capturing with the fields in the wrong order?”
    I’m using a stock AJA Composite to DV Codec. The same as I’ve always used. Dumb question-How would I know if the fields are in the wrong order?
    “Is your Beta deck locked to the same reference as your IoLa?”
    Yes- I have a BB Gen going to both
