Activity Forums AJA Video Systems Frame Flicker Problem
  • Frame Flicker Problem
    Posted by Meesta Joe on August 11, 2006 at 1:09 pm
    I’m not sure what the cause is, but lately when I digitize from my Beta SP (UVW 1800) with vis Timecode Burn-in through my Aja Iola, I see Timecode from two consectutive frames supperimposed on each other. I’m not sure if it’s due to a Quicktime Update, FCP Update or what. This never used to happen. It doesn’t happen on my Computer- only on my external Monitor.
    I’m using FCP 5.1, QT 7.1 with Aja Iola 2.1 (This is what Aja recommended to use with my setup) and a G5 Dual 2G
    Any suggestions?
    Thanks in advance!
    Jeremy Garchow replied 20 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 15, 2006 at 9:00 pm
    Can you post a still?
    have you tried uninstall and reinstall drivers/firmware?
