Activity Forums VEGAS Pro frame by frame preview not matching the render
  • frame by frame preview not matching the render
    Posted by Terry Creech on August 19, 2010 at 3:34 pm
    I have two clips.
    Clip 1: Jeff Gordon crashes and then it cuts to an interview of him.
    Clip 2: Tony Stewart crashes.
    I clip out the interview and include as much of the Gordon crash as possible (so that the next frame would be the interview). Then the Stewart crash is added right beside it.
    When doing a frame by frame preview (shows the frame number of 101,102,103,104 etc.) it appears exactly how i want it but after rendering, a couple of unwanted frames of Gordon’s interview are added (rendered video will look like Jeff Gordon crash, couple unwanted frames of his interview, Tony Stewart crash).
    How is it that the render is including these few unwanted frames at the end of the first clip when it previewed perfectly? Has anyone else experienced this and is there a solution to fix it?
    Terry Creech replied 16 years ago 1 Member · 1 Reply
  • Terry Creech
    August 19, 2010 at 4:09 pm
    I should mention that it doesn’t seem to matter the format of the clips i’m working with. I work with avi’s, mpeg’s, and vob’s mostly and i can tell you the problem has definitely occurred with MPEG and VOB files.
