Activity Forums Adobe After Effects Frame-by-frame drawing in After Effects
  • Frame-by-frame drawing in After Effects
    Posted by Chris Thomas on July 17, 2013 at 9:58 pm
    Hi everyone! I’ve been searching this forever, and am amazed that I can’t find (or think of) a simple solution to this:
    I want to use AE to draw individual shapes with the brush tool that last for one frame only. This is easily done with the brush tool and “paint” effect.. but here’s the problem:
    I want to use this to draw frame-by-frame animations directly in AE, which means I need to see a shadow of the previous and upcoming frames so I can draw the motion properly. My current workflow of drawing, skipping back one frame, re-drawing, skipping backwards again, and re-drawing again is just an inefficient way to work. It’d be great if I could see a shadow of the frames before and after as I worked.
    Is there a way to do this? If so, I’d love some insight.
    Chris
    Frank Boxman replied 8 years, 6 months ago 7 Members · 20 Replies
  • 20 Replies
  • Jeff Hinkle
    July 17, 2013 at 10:23 pm
    Onion skinning is a common feature request (that seems to go ignored). A little searching turned up this script. I haven’t used it personally but folks seem to have had success with it. Might be just what you need.
    https://www.aenhancers.com/viewtopic.php?f=11&t=871
    It is easier to destroy than to create.
    More fun, too.
  • Chris Thomas
    July 17, 2013 at 10:33 pm
    Unfortunately the script doesn’t work because all of the “painting” in AE takes place within a layer window, not a comp window. That means onion-skinning a comp would only help you after you’ve already drawn the animation—not while you’re currently in the layer window painting it.
    I think either one of two things needs to happen:
    1. There needs to be a way of painting/drawing in AE without having to open the layer up in an official “layer window” (something that’s incredibly annoying and should go away regardless)
    2. There needs to be a way to turn on onion skinning within a layer window
    Thanks for the thought though, Jeff! Anyone else out there have an idea? I feel like there should be—somewhere—a third-party plugin that utilizes the brush tool for this sort of simple thing.
  • Joseph W. bourke
    July 17, 2013 at 11:16 pm
    This sounds like a job for Photoshop – you should have no trouble doing your frame by frame animation in PS in a timeline, then exporting to After Effects:
    https://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e41001031ab64-746fa.html
    Photoshop was made to do this.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Todd Kopriva
    July 18, 2013 at 5:27 am
    No, not ignored. I address this here:
    https://blogs.adobe.com/aftereffects/2012/12/top-feature-requests-for-after-effects-in-2012.html
    … and it was a major topic in a feature planning meeting that we were having today.
    If you want a feature, submit a feature request:
    https://www.adobe.com/go/wish
    This really helps.
    After Effects team blog
  • Chris Thomas
    July 18, 2013 at 12:59 pm
    Hi Joe,
    Yes, I know this can be done in Photoshop.. but I still don’t find the workflow ideal—
    • Make a new layer
    • Change opacity of layer below
    • Draw a new shape
    • Repeat
    • Change all opacities back to 100
    • Export image sequence
    • Import image sequence
    • Review
    • Make changes
    • Repeat
    AE is one step off from having a beautifully simple interface which allows me to draw, hit “page down,” draw again, then hit “0” when I want to watch the whole thing. It would allow for such better iteration and faster workflow.
    I’ve been doing my animations in PS now and it’s just not as simple as it could be in AE. Being able to preview what I’ve done after a few frames would be unbelievably helpful.
    Thanks for the thought, though—
    C
  • Chris Thomas
    July 18, 2013 at 1:05 pm
    Hey Todd—
    Exciting that you’ve addressed this issue in a meeting yesterday! Glad to hear it’s on the table.
    If you have a moment, I’d love it if you read my specific thoughts on drawing frame-by-frame animation in AE. I’m not sure of onion skinning will only be available in the Vector Paint effect, but it would be great to have it in the normal “Paint” effect, too.
    It seems as if having a way to paint frame-by-frame in AE is such a low-tech solution that it’s not really addressed in the software. However, as motion graphics continues to use more and more hand-done work, it’s a feature that I find myself needing more and more.
    Anyways! My two thoughts. Thanks!
    Chris
  • Jason Jantzen
    July 18, 2013 at 1:36 pm
    Some of the best frame by frame animators I know use PS for their workflows and have no complaints. Here are a couple of tutorials on the subject –
    https://vimeo.com/23707998
    https://vimeo.com/39659667
    I mean, in the meanwhile, that’s probably the best way to get your looks. This is the guy who suggested those 2 videos –
    https://vimeo.com/69938948
    Jason Jantzen
    vimeo.com/jasonj
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Chris Thomas
    July 18, 2013 at 1:43 pm
    Thanks for the links! I’ve used both of those tutorials in the past, and they’re great. Also, love the work that Daniel does—he’s got a fantastic eye for frame-by-frame stuff.
    I know a lot of people use PS (including me), but I still think there’s a huge market for being able to do a lot of that work in AE. AE is made for motion, and PS isn’t (despite their continued updates to the software). For me, I’d love to see it all happening within the software that I’m using for all the rest of my animation work.
    In the meantime, PS will work for me.. I’m just throwing out a line in case anyone else feels the same way.
  • Jason Jantzen
    July 18, 2013 at 1:48 pm
    I’ve never actually done any frame by frame animation, but of all the stuff I’ve seen, it would seem easier to me to do it in Photoshop considering all the painting tools you have vs the crude brush palette in AE.
    Jason Jantzen
    vimeo.com/jasonj
  • Chris Thomas
    July 18, 2013 at 1:52 pm
    Oh yeah—for some stuff, absolutely! But for a lot of smaller effects, having a simple 2-10 pixel hard-edged brush is all I need.. and for that, AE would be perfect.
