Activity › Forums › AJA Video Systems › frame buffer question
  • frame buffer question
    Posted by Mark Palmos on September 19, 2007 at 1:34 pm
    hello all
    I have an LHe with FCPStudio2 and CS3 (soon)
    Im not a very experienced FCP user, so excuse the question if it is very basic, but my Kona/FCP combination seems to be demonstrating the same kind of “frame buffer limitations” that my old Targa 2000 card used to suffer from.
    An example is when you have a timeline containing a nested clip, and that nested clip is a subtimeline containing a series of clips with disolves between them. It seems that if you want to give a transparency to the nested clip in the parent timeline, the disolves between the clips in the nested timeline will show up as cuts!
    Is this really the case, or was i doing something wrong?
    Mark.
    Jeremy Garchow replied 19 years ago 2 Members · 3 Replies
  • Jeremy Garchow
    September 19, 2007 at 9:09 pm
    Let me get this straight.
    You have a sequence full of clips with dissolves.
    Then you have a master sequence where the above sequence is nested, then you pull the opacity down of that clip (or nest). Then there’s no more dissolves?
    If that’s what you mean, i have set up a similar example and it works as expected i.e. the nest is less opaque and dissolves work as normal.
    Jeremy
    What version of everything are you on?
  • Mark Palmos
    September 19, 2007 at 9:13 pm
    Hi Jeremy,
    Thanks for the response.
    Im home now, will check it tomorrow.
    I hope I’m remembering what I was doing that didnt work as expected… i immediately went to a plan B, and had a very busy day, so will find a moment to try replicate it tomorrow.
    as far as you know, however, should any number of layers with alpha channels and disolves etc, work?
    ta
    mark
  • Jeremy Garchow
    September 19, 2007 at 9:30 pm
    As long as you have everything setup properly, and in my personal experience yes.
    Jeremy
