Activity Forums Adobe After Effects Frame Buffer error help
  • Frame Buffer error help
    Posted by Thadtrick on April 6, 2007 at 4:27 pm
    Hello all,
    I am doing and animation comprised of a large photo with 3D layers and a camera. I am doing “The Kid Stays in the Picture” type effect giving synthetic depth and animation to still images.
    I rendered this piece (1 min 20 sec) out a couple days ago and it rendered from start to finish with no problems. I’ve made revisions to some areas and am tring to re-render and am now getting various frame buffer error messages at points that did not change that rendered fine previously. I am now resorting to render in chunks and re-assemble. I could understand if it might be parts that I added more layers to that were crapping out. Not sure what is going on.
    Have plenty of storage and memory.
    Is there a frame buffer limit or suggested size not to exceed with large still or still comps?
    The most current error message was “Could not create a 6000 x 3400 frame buffer error message”.
    I know that’s a sizeable comp….but I thought AE could handle that no prob….and it DID a couple days ago.
    What could have changed?
    I purged all caches and memory….just in case.
    What should I be looking at here?
    Thanks in advance!
    ~Thad
    AE 7 Quad core dual 2.5GHz G5/ 4 GB RAM
    Jan Sherlink replied 19 years, 4 months ago 4 Members · 5 Replies
  • Thadtrick
    April 6, 2007 at 4:57 pm
    Not so much revisions…..as it was sweetening….adding a few more layers here and there…..reanimating/adjusting some of the camera moves and keyframes….giving more z-depth here and there to exaggerate the 3d depth on the moves. Going back into Photoshop and re-touching some things.
    The weird part is…the problematic parts where it craps out….I didn’t really touch.
    Thad
  • Darby Edelen
    April 6, 2007 at 4:58 pm
    [thadtrick] “I purged all caches and memory….just in case.
    What should I be looking at here?”
    Purging the caches usually alleviates any frame buffer problems I’m having. Usually my next step is restarting AE, then restarting my computer.
  • Thadtrick
    April 6, 2007 at 5:26 pm
    Y’know I was just thinking about rebooting….the usual snake oil for a lot of AE unsolved mysteries.
    Didn’t want to take the time to do it. Might as well give it a try.
  • Julian Sixx
    April 6, 2007 at 6:22 pm
    Hi
    here you can find pretty useful information about this issue
    https://generalspecialist.com/archive/2006_11_01_archive.asp
    scroll down a bit.
  • Jan Sherlink
    April 7, 2007 at 10:27 am
    Slicing up your picture and keeping them organised with parenting is the way to go.
    …or…
    In AE:
    Hold Shift
    Click Edit-Preferences-General (still holding shift)
    In the drop down menu you’ll see “Secret”
    There you can set the “purge every…frames”
    renders take longer … but is renders !
    cya,
    Jan
