Activity Forums Adobe Premiere Pro Frame Breach Notification in Premiere Pro?
  • Frame Breach Notification in Premiere Pro?
    Posted by Sam Kallas on June 24, 2021 at 12:42 pm
    Hello Everyone,
    I am reframing videos of sports live classes originally shot in 16:09 to 1:1 aspect ratio
    in the process I have to keep the coach in the center of the frame and prevent his hands and legs of going outside the frame.
    Is there an automated way? AI? Plugin? Or anything that would detect when the coach’s hands or feet have gone outside the frame so that i can use keyframes to reframe him?
    Thank you.
    Samer Kallas ▬ Editor
    Oliver Peters replied 5 years, 2 months ago 2 Members · 1 Reply
  • Oliver Peters
    June 24, 2021 at 3:39 pm
    Premiere Pro includes an Auto Reframe feature that will do this all automatically. After you create the 1:1 sequence, you can then go in shot-by-shot and make adjustments if you need to offset the reframing. You can also override the AI-generated keyframes and manually create your own if needed on some specific shots. Also any graphics may need to be modified to fit properly.
