Activity Forums Adobe After Effects Expressions Frame Blending using Expressions
  • Frame Blending using Expressions
    Posted by Sacha Sojic on January 20, 2013 at 6:14 pm
    Hello all,
    Does anyone know if there is a way to toggle frame blending modes within a layer (off / frame mix / pixel motion) using keyframes and expressions? When using layers as luma or alpha mattes, splitting layers to change the blending mode can become messy. I’m looking for a possible workaround. I’m using AE CS6.
    S. Sojic
    Montreal
    Sacha Sojic replied 13 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 20, 2013 at 7:21 pm
    You can’t control the frame blending mode directly. The only thing I can think of would be use a copy of the layer for each mode and control the opacity with keyframes, or expressions based maybe on layer markers that define which mode you want. It might be more trouble than it’s worth though.
    Dan
  • Sacha Sojic
    January 24, 2013 at 2:19 am
    Thanks for the suggestions Dan,
    I’ll keep researching the options, though. Duplicating layers or splitting them amount to pretty much the same thing, as far as I’m concerned. Any modifications to a parameter would mean pasting it to all of the duplicated layers, which defeats the purpose.
    The layer markers are an interesting cue. I’d love to find out if frame blending mode can be linked to specific points in the timeline. I might be a pipe dream but I’ll keep looking.
    S. Sojic
    Montreal, Qc
