Activity › Forums › Adobe After Effects › frame blending time remapped pre-comps
Posted by Tom Ma on December 2, 2010 at 4:35 pmIs it somehow possible to frame blend pre-comps in a composition?
This would really be handy.I have a pre-comp with CG renders, and want to globally re-time that comp, but I do not have the options of frame blending (or interpolation)
thx.
Tom Ma replied 15 years, 9 months ago 3 Members · 5 Replies -
Kevin Camp
December 2, 2010 at 6:43 pmif your pre-comps contain footage, then enable frame blending for those footage layers in the precomps. when you render with frame blending (or enable it for preview renders) that footage will then be frame blended.
for other, non-footage elements, ae’s native motion blur usually works. when enabled, it should ramp up the blur amount with the time remap.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Walter Soyka
December 2, 2010 at 9:34 pm[Tom Masters] “I have a pre-comp with CG renders, and want to globally re-time that comp, but I do not have the options of frame blending (or interpolation)”
Just to add to Dave and Kevin’s excellent advice, you could also use AE’s Timewarp effect, or RE:Vision Effects’s Twixtor. Both use motion estimation to retime comps, and both offer far more flexibility and control than simply turning on frame blending. If you have or can render a motion vector pass from your 3D app, you can use it with Twixtor Pro for better retiming.
Closely related to this topic is motion blur; RE:Vision has another tool called ReelSmart Motion Blur which uses motion estimation to add (or reduce) motion blur. I’ve been using RSMB Pro Vectors, in conjunction with a motion vector pass from my 3D render, to add motion blur post-render.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Tom Ma
December 2, 2010 at 10:03 pmDave: didn’t I say I was rendering CG passes? That is FOOTAGE, which makes total sense to re-time.
And apparently from Kevin’s reply, it is very possible. I tested it, works great.(If ya don’t know, it might be best not to answer. Just sayin’)
Tom Ma
December 2, 2010 at 10:15 pmvery helpful, thx.
I just find the standard time re-mapping very intuitive, and now with motion estimation built in (as of CS3 I think) it is super handy.
