Activity › Forums › Apple Motion › frame blending in retiming “behavior” parameters
  • frame blending in retiming “behavior” parameters
    Posted by Bob Roberts on September 19, 2007 at 3:40 pm
    When I look at a clip under INSPECTOR>PROPERTIES>TIMING, I get a certain set of adjustable parameters including the type of frame blending used in retiming.
    If I use a retiming behavior, I don’t get those same parameters under INSPECTOR>BEHAVIORS.
    So my question is, if I use a retiming behavior, how can I define what type of frame blending method to use?
    Thanks in advance.
    Bob Roberts replied 19 years ago 2 Members · 2 Replies
  • Doyle Rockwell
    September 19, 2007 at 11:07 pm
    Howdy,
    The retiming behaviors respect the blending mode set on the layer.
  • Bob Roberts
    September 20, 2007 at 2:55 pm
    That’s what I figured and I’m trying to find a way to work around that. The problem is that ultimately the frame blending (…in this case optical flow) actually “blurs” the area that I’m not retiming because, as you stated, it applies to the entire layer.
    Any thoughts?
