Activity Forums Adobe After Effects Frame Blending in AE vs Premiere
  • Todd Kopriva
    May 23, 2011 at 3:49 pm
    Yes.
    Pixel Motion uses optical flow technology (similar to what is in Twixtor) to create motion vectors and use those to interpolate frames. This is the same as the highest-quality option in the Timewarp effect.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Darby Edelen
    May 23, 2011 at 6:58 pm
    [Todd Kopriva] “This is the same as the highest-quality option in the Timewarp effect.”
    With the caveat that the Pixel Motion that Frame Blending uses cannot be adjusted for your footage, it’s using a sledge hammer where you need a scalpel 🙂
    I have never had good results using this mode of Frame Blending. To avoid tearing and jello you’ll need to use the included Timewarp effect or something like Twixtor and you’ll likely need to tweak the parameters for your footage. You may even need to keyframe parameters over the course of a shot.
    Darby Edelen
