Activity Forums Apple Motion Frame blending for the retimed part only?
  • Frame blending for the retimed part only?
    Posted by Laszlo Jancsik on April 13, 2011 at 12:49 pm
    I’m trying to speed up the end part of a clip with frame blending ON. It’s almost fine, but frame blending is applied to the entire length of the clip, even where it plays back at 100%. Is there a way to avoid that?
    I really need the blur on the fast part, but not on the other. Any suggestions are highly appreciated 😉
    Zak Peric replied 15 years, 5 months ago 3 Members · 2 Replies
  • Gareth Randall
    April 14, 2011 at 6:52 am
    Split the clip at the frame where you want the retiming to start and then apply the retiming to just that section.
  • Zak Peric
    April 14, 2011 at 9:11 am
    To split the clip you need to do this in the timing pane not a project pane. Select the clip in the timing pane and place a yellow tooltip icon where you want it to split. Then under the edit menu (I think under that menu) use split command.
